02-29-2024 07:44 AM
My router has failed. No power over ethernet to ruckus wifi on ceiling or to doorbell.
How do I get a replacement and RMA for my router?
02-29-2024 08:03 AM
admin test
02-29-2024 08:04 AM
Hi @carrtommy
As per the case description, I understand that your RUCKUS setup is not working, and Access Points do not have power.
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please let me know the answers to ALL the above queries and let me know if you have any queries in this regard.
