07-12-2025 08:52 PM
My Unleashed Ruckus has a Green light and an amber light. My AP will not power on even with a reset.
07-21-2025 07:35 AM
Hello @Nikkilee ,
I understand that you have completed reset on the Switch.
As the reset was not performed successfully, the only option is to perform Software recovery.
Please note, you must use ethernet cable (both ends RJ45 plugs) and USB to type C cable both together for Software Recovery process as described in steps 2 & 3 in the guide link.
May I please know if you have an option to arrange a laptop with an Ethernet cable port to complete the software recovery process?
07-23-2025 07:24 AM
Hello @Nikkilee ,
07-25-2025 12:33 PM
Hello @Nikkilee ,
07-29-2025 06:21 AM
Hello @Nikkilee ,
07-31-2025 07:07 AM
Hi @Nikkilee ,
Thank you.
