โ05-01-2024 12:01 PM
After power outage had to reconfigure ruckus. All other apple products connect fine only the macbook
air will neither connect to ruckus or its ssid
โ05-01-2024 12:11 PM
Hi @JoeB
As per the case description, I understand that you are unable to connect your MAC Book device to the RUCKUS Wi-Fi and other devices work fine,
Could you please forget the RUCKUS Wi-Fi on the MAC book device and try to connect once again?
Please check and let me know if that works.
โ06-28-2024 12:43 PM
I had the same problem as you and I had to remove everything and reinstall it to fix it
โ06-28-2024 12:56 PM
Hi @daviftv
We appreciate your correspondence and trust you are well. Your information has been received and noted.
Should you encounter any challenges with your RUCKUS devices, we encourage you to submit your query to RUCKUS Lennar Support for prompt assistance.
Thank you once again for your understanding and cooperation.
