12-26-2022 09:59 PM
I want to connect my living room TV to the internet using my a ethernet cable. The ethernet cable outlet in the living room is not working for some reason.
My TV in the upstairs loft is connected to a Ethernet cable and it’s working perfectly fine.
what can I do???
thanks
12-27-2022 09:05 AM
can you you please draw an arrow to which porter I need to use?
12-27-2022 09:11 AM
Hi @EMRuckus
Any of the 12 available ports in the middle part ( in the red section ) Like the below picture:
Best Regards
Fernando Vasquez
12-27-2022 09:30 AM
Can I send you a photo of my set up? Mines has a bunch of blue Ethernet cables.
12-27-2022 09:37 AM
12-27-2022 09:50 AM
Photo #1
Full internet setup. The WHITE cable is the Ethernet cable plugged into my modem/router currently. I’m not sure what the BLUE cables are used for.
Photo #2: Here is a closer look at the switch boxes and the cables plugged in it.
Photo#3: Here is my modem/router from the internet provider
Also, currently this setup is allowing me to get connection to my Ethernet plug outlet in my upstairs loft TV. I just need help getting connection to my living TV.
SIDE NOTE:
What LED colors should be appearing on my wifi booster?
thanks
