02-15-2021 08:41 AM
I haver a new Lennar home and we have random power surges. Everytime the wifi becomes intermittently non responsive, sluggish, and all smart home devices are non-responsive or extremely delayed. I have tried, unplugging router, doing a hard reset on AP, but no success this time. Is there documentation on how to configure the AP on the Ruckus dashboard. Maybe I am missing something. Any other suggestions?
Thanks!
06-28-2021 11:01 AM
Same issue here - the funny thing is the rockus and ATT worked great for about 1 year - now all of a sudden connections drop and wifi is horrible
event hardwire devices have connection drops
if I connect directly to the ATT router issues solver - no drop connections hardwire or over wifi
its like if they had a n internal firewall with a mind of its own
08-05-2021 01:03 PM
06-02-2022 07:02 PM
Lennar home owners & Wi-Fi issues (solved):
This is an informational posts to hopefully help those that are having Wi-Fi issues and live in a Lennar home. Symptoms include a frequent inability to connect to the internet / load webpage.
In the smart panel, there is a device (Ruckus switch) that connects your internet connection to your wireless access point (in your ceiling). I recently found that my devices could not access the Internet, even though they connected to the Wi-Fi access point.
I found the cause of the problem to be the Ruckus switch that had failed, sort of like when you ox hard drive crashes. I found this by replacing this device with another switch I got off Amazon for <$30.
Why Lennar put this device in there is unknown, as the devices go for about $$650 or more and are complicated to work with without a solid background in networking.
Hope this helps people and may help others.
08-04-2021 12:15 PM
Hi, have this issue been solved? I also have a new Lennar house and everything was working properly until 2 days ago when I had a power outage and not everything connected through the AP is either not working meaning no internet or super sluggish connectivity. I tries rebooting all the devices including the ATT router but no luck. Any advice is much appreciated. I have the ICX 7150 and 2 x AP (541)
08-05-2021 01:06 PM
@jay_lasad same with me, everything went slow after the power outage. My ISP replaced the Gateway with their new model and no issues after that. Easy fix. Hope that helps.
