03-14-2025 02:12 PM
I am told by Sonos that there is a known issue connecting issue connecting a Sonos sub woofer with the Ruckus router. I was told to have Ruckus disable the
Directed Multicast/Broadcast
can you please help
03-17-2025 05:19 AM
Hi @Andre014
Based on the information provided, it appears that you are encountering issues with the RUCKUS-Sonos setup.
We may need to try the below steps to connect the Sonos setup with the RUCKUS Wi-Fi. We need CLI access to the Master Access Point. For this, we need the Master Access Point’s IP Address to access CLI.
Please follow the below steps on how to find the Master AP’s IP Address and access CLI to perform the commands.
Please follow the below steps to access CLI and perform commands:
1. We must identify the ‘current’ IP address assigned by your local router to the RUCKUS Master Access Point. Please log into the RUCKUS Unleashed system and find the Master AP’s IP address.
If you encounter difficulties accessing the above link or if you are unsure of the IP Address of your Access Points, please refer to our guide on finding the IP Address of the Access Point:
You should see the below-Unleashed dashboard after finding the IP Address of the AP. Try to log in. (Refer to the screenshots below)
2. Once we identify the IP address of the Master Access Point, proceed to access remotely the device “Command Line”
Please download the Putty Application and try to log in to the CLI using the Master AP’s IP Address.
Putty download link:https://www.putty.org/
Try the SSH option to log in to CLI (Putty) as described below- Please refer below.
SSH- Port 22
ruckus>
Please enter the below commands once you log in to CLI.
ruckus> enable
ruckus# config
ruckus(config)# show wlan
ruckus(config)# wlan hotspot (Please refer below point***)
ruckus(config-wlan)# no qos directed-multicast
ruckus(config-wlan)# qos directed-threshold 0
ruckus(config-wlan)# end
***The ‘show wlan’ command will display the name of the Wi-Fi Network/SSID, so please put in your Wi-Fi Network/SSID. In the above command, my SSID/Wi-Fi network name is ‘hotspot’ (refer to the below screenshot)
Once you perform all the above commands, please restart your SONOS setup and check.
Let me know how it goes.
03-17-2025 05:26 AM
Hi @Andre014
I hope you are doing well.
Kindly follow the steps outlined in my previous message and let me know the outcome. Should you encounter any difficulties or have further questions, please don't hesitate to reach out.
