โ02-15-2024 06:51 AM
Good morning,
I have AT&T gateway supplying a Ruckus switch which then supplies a Ruckus R320 AP. The AP appears to be behaving intermittently. When I connect via phone or on another device the pages freeze then load after 5-10 seconds. I have also performed speed tests comparing the R320 AP to the AT&T gateway and the results vary. I requested a new AT&T gateway which I installed last night and the issue has not been resolved. Please advise next steps in resolving, thank you!
โ02-15-2024 10:55 AM
I tried connecting directly to the gateway via ethernet and now I am receiving "Network Error: Connection timed out"
โ02-15-2024 10:58 AM
Hello @dreyes1113
1) How did you identify the IP address of the Switch?
2) What happens if you put the IP address in the URL of the web browser
You can share any screenshot related
Fernando Vasquez
โ02-15-2024 11:03 AM
1. To identify the IP address of the switch I used the IP address of the AT&T gateway and located it through the device list.
2. If I type in the IP address of the switch into my web browser I am prompted with a username and password request
โ02-15-2024 11:08 AM - edited โ02-15-2024 11:09 AM
Hello @dreyes1113
Perfect I believe we are making progress.
Are you trying to connect using SSH or Telnet through the Putty tool ?
Please use the following guide as reference :
Fernando Vasquez
โ02-15-2024 11:13 AM
Yes - I have tried both SSH and Telnet through the putty tool with no success. I continue receiving connections errors with Telnet, through SSH I am prompted for a password but it will not let me type anything.
