12-25-2023 06:25 PM
Hi Admin,
My ICX7150 switch failed with SYST amber light on. Tried updating primary, secondary and uboot. Post update when I do the reset, I continue to get the below message on the console. Pls help me.
[BrcdSoftlockup]: BUG: soft lockup - CPU#0 stuck for 89s! [mount:601]
000066a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
01-02-2024 01:31 PM
Hi Imran, yes I was able to solve the problem. Thank you for all the support.
12-26-2023 05:34 AM
Hi @ShanPSP
As per the case description, I understand that your RUCKUS setup is not working, and you are trying to software recover on the Switch.
Could you please share a screenshot of the error and a picture of the software recovery cable connections between the Switch and the laptop?
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
12-26-2023 07:05 AM
Hi Imran, Thank you for the support. I was successfully able to console into the switch. Looks like my software recovery. has worked. But I get the below error message when I boot the switch. I get the warning messages as below. Also Now there are no Amber lights. Now what's the next step after the software recovery to configure the switch.
Hash value: c027c7ec
## Loading kernel from FIT Image at 70000200 ...
Using 'conf@1' configuration
Trying 'kernel@2' kernel subimage
Description: Ruckus Linux MN VER=08.0.90k
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x7024fcd0
Data Size: 2401842 Bytes = 2.3 MiB
Architecture: ARM
OS: Linux
Load Address: 0x61008000
Entry Point: 0x61008000
Hash algo: crc32
Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 70000200 ...
Trying 'ramdisk@1' ramdisk subimage
Description: Ramdisk -rootfs
Type: RAMDisk Image
Data Start: 0x704a0cb8
Data Size: 23843872 Bytes = 22.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: crc32
Hash value: 1e3b36e9
## Loading fdt from FIT Image at 70000200 ...
Trying 'fdt@3' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x7049ea60
Data Size: 8607 Bytes = 8.4 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 6fc9a37b
Loading fdt from 0x7049ea60 to 0x65008000
Booting using the fdt blob at 0x65008000
Uncompressing Kernel Image ... OK
Using Device Tree in place at 65008000, end 6500d19e
Starting kernel ...
Mounting file system...
booting with 4.4 kernel
PLATFORM MN
dd cmd: UBI
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: crc32
Type: RAMDisk Image
Architecture: ARM
OS: Linux
Hash algo: crc32
Architecture: ARM
Hash algo: crc32
Starting kernel ...
PLATFORM MN
dd cmd: UBI
Starting kernel ...
PLATFORM MN
dd cmd: UBI
Config partition mounted
Resource partition is mounted!!
Processing packages from primary partition
Incompatible version of booted application and packages stored in UFI image
Error, cannot install packages
Uninstalling old packages if any..
Error in processing packages
Package installation is incomplete, related functionalities may not be available
dhcpd executable file is not present.
Starting up system statistics daemon...
Starting systatsd done
Log Level 7: Daemonized systatsd
Systatsd Logging Env is not set, initializing loglevel to: 7
Setting connection to systemlogger
Starting up health monitor daemon...
Starting hmond done
Hmond Logging Env is not set, initializing loglelvel to: I
Backup is fine
Kernel crashdump is disabled.
dma_mem_base: 0x96000000, dma_mem_len: 0x8000000, warm_mem_base: 0x9f500000, warm_mem_len: 0xb00000
Creating TUN device
Starting TPM Infra
Group tss and User tss created
kernel.hostname = localhost
hostname set to localhost
Starting TCSD Daemon
TCSD Up and Running
Enabling time stamp
========== WARNING: Boot-monitor version mismatch!!! ==========
========== Please use "show boot-monitor" command for details ==========
=============== WARNING: FI image is not booted from UFI!!! ===============
====== Please download UFI image and reboot the system for full functionality ======
12-26-2023 07:22 AM
Hi @ShanPSP
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
Please let me know the answer to the above query or let me know if you have any queries in this regard.
01-02-2024 01:31 PM
