02-27-2025 11:57 AM
So I am running into problem where my switch is stuck as pending. I tried switching the code through the CLI and changing the boot sequence to primary in the web interface but nothing is working. I also tried upgrading the switch but get an error saying bootrom is an invalid input. Below are my screenshots.
Show flash:
Show version:
Copy flash flash secondary error:
Boot sequence set to primary in web interface:
Bootrom error when trying to upgrade:
02-27-2025 12:06 PM
Hi @mfielding
Based on the information provided, it appears that your Switch is stuck on the Routing Code.
copy flash flash secondary
Example:
Regarding the Switch upgrade process, we recommend transitioning to version 08.0.95g, identified as the stable version for Lennar Home users.
To facilitate this transition, we have recently introduced an upgrade tool tailored to ensure a seamless process. Utilizing this tool is straightforward: users simply need to input the IP Address, Username, and password associated with the Switch into the software interface.
For your convenience, please find the necessary resources below:
We highly value your input and would greatly appreciate your feedback on our upgrade tool. Your insights are instrumental in our ongoing efforts to enhance user experience and ensure the tool meets your needs effectively. Please take a moment to share your thoughts, suggestions, or any issues you encountered while using the tool. Your feedback is invaluable to us and will guide us in further improving the tool for all our users. Thank you for your time and contribution.
Should you require any assistance throughout the process, please do not hesitate to reach out. Your satisfaction is our priority, and we are here to support you every step of the way.
02-27-2025 12:06 PM
Hi @mfielding
Example:
02-27-2025 12:08 PM
Hi @mfielding
Please refer to my last post and let me know how it goes.
02-27-2025 01:20 PM
Hi Imran,
Thank you for the quick reply. The upgrade tool worked but now my switch is stuck on "connecting". How do I resolve this?
02-28-2025 04:19 AM
Hi @mfielding
Before I assist you further with this, could you please share a full screenshot from the Unleashed system where it says that the Switch is in the connecting state?
Additionally, please share the output of the below commands from the Switch CLI:
show ip address
