ICX 7150 Won't Write to Flash
diver19743
I have an ICX 7150 running on the latest SPR UFI code. I am trying to upgrade to the Switch firmware but I am getting an error writing to flash. I have tried from the Web CLI and the console through SSH. Each time, it copies and fails at 25% when writing. I have tried a new download and after several reboots, but no go. I have saved off the support files from the web upgrade.
27 REPLIES 27
The switch finally recovered but I have been having so many network issues that I purchased 2 POE+ injectors to connect my R510s to my AT&T router. Now that I have the switched by-passed, I can work on it from my desk. I have still be unable to get the USB drive to be detected.
Hi @diver19743
Could you please let me know if you are able to access CLI via Putty now?
I have access to the CLI via putty, but I am unable to get the device to recognize any USB thumb drive. I have used old ones and newer ones. I have used 3rd party partition software to format the device to FAT32, but no luck.
ICX7150-C12 Router#mount disk0
External USB is not present.
ICX7150-C12 Router#
Hi @diver19743
Could you please enter the below commands once you log in to Putty CLI and share the output?
show version
show inline power
show inline power detail
ICX7150-C12 Router#show version
UNIT 1: compiled on May 2 2023 at 22:09:30 labeled as SPR09010f
(33554432 bytes) from Primary SPR09010f.bin (UFI)
SW: Version 09.0.10fT213
Compressed Primary Boot Code size = 786944, Version:10.1.25T225 (mnz10125)
Compiled on Mon Aug 8 11:58:28 2022
HW: Stackable ICX7150-C12-POE
Serial #:FEK3849Q2H2
Software Package: ICX7150_BASE_L3_SOFT_PACKAGE
Current License: 2X1G
8 MB boot flash memory
2 GB code flash memory
1 GB DRAM
STACKID 1 system uptime is 2 hour(s) 16 minute(s) 31 second(s)
The system started at 22:09:39 GMT+00 Tue May 02 2023
ICX7150-C12 Router#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 124000 mWatts.
Power Allocations: Requests Honored 12 times
1/1/1 On Off 0 0 n/a n/a 3 n/a
1/1/2 On Off 0 0 n/a n/a 3 n/a
1/1/3 On Off 0 0 n/a n/a 3 n/a
1/1/4 On Off 0 0 n/a n/a 3 n/a
1/1/5 On Off 0 0 n/a n/a 3 n/a
1/1/6 On Off 0 0 n/a n/a 3 n/a
1/1/7 On Off 0 0 n/a n/a 3 n/a
1/1/8 On Off 0 0 n/a n/a 3 n/a
1/1/9 On Off 0 0 n/a n/a 3 n/a
1/1/10 On Off 0 0 n/a n/a 3 n/a
1/1/11 On Off 0 0 n/a n/a 3 n/a
1/1/12 On Off 0 0 n/a n/a 3 n/a
Total 0 0
ICX7150-C12 Router#show inline power detail
Power Supply Data On unit 1:
Power Supply Data:
Power Supply #1:
Max Curr: 2.3 Amps
Voltage: 54.0 Volts
Capacity: 124 Watts
PoePower: 124 Watts
POE Details Info. On Unit 1 :
General PoE Data:
Firmware
Version
02.1.8 Build 004
Hardware
Version
V2R4
Device HW version : 0:V2R4 1:V2R4
Device Temperature(deg-C) : 0:46 1:52
Device Status : 0:Good 1:Good
Cumulative Port State Data:
#Ports #Ports #Ports #Ports #Ports #Ports #Ports
Admin-On Admin-Off Oper-On Oper-Off Off-Denied Off-No-PD Off-Fault
12 0 0 12 0 12 0
Cumulative Port Power Data:
#Ports #Ports #Ports Power Power
Pri: 1 Pri: 2 Pri: 3 Consumption Allocation
0 0 12 0.000 W 0.000 W
ICX7150-C12 Router#
