06-27-2023 01:35 PM
I have an ICX 7150 running on the latest SPR UFI code. I am trying to upgrade to the Switch firmware but I am getting an error writing to flash. I have tried from the Web CLI and the console through SSH. Each time, it copies and fails at 25% when writing. I have tried a new download and after several reboots, but no go. I have saved off the support files from the web upgrade.
06-30-2023 03:44 PM
I rebooted the switch and ran the cmd again and got the exact same error as the last one. I can post the same error again if you want with a different timestamp.
06-30-2023 05:05 PM
Hi @diver19743
Please try to Upgrade using below options as well.
Below are the options or methods to perform the Upgrade on the switch:
1st Option:
1. In this option, we will use a pen drive or USB flash drive in which we move the files to the pen drive and connect it to the Switch then through CLI we execute the commands to upgrade the Switch using the following guide as a reference:
2nd Option:
2. In this option we Upgrade the Switch from the Web Interface (GUI) of switch.
07-07-2023 05:24 PM
I have been having a nightmare with this device. I inserted the USB drive and the system freaked out, nothing would show up on my console connection via putty. I had to perform a factory reset and then the device keeps rebooting itself.
Ruckus-ICX login:
Login timed out after 60 seconds
Press any key to continue..
[ 600.670064] [BrcdSoftlockup]: Time elapsed since core-collection started (283) secs. Max Timeout(1800) secs
Press any key to continue...
[ 690.670075] [BrcdSoftlockup]: Time elapsed since core-collection started (367) secs. Max Timeout(1800) secs
Segmentation fault (core dumped)
Tue May 2 22:17:09 UTC 2023: Core file collected as /tmp.gz, processing the core file ...
Tue May 2 22:17:09 UTC 2023: Calculating checksum: core_2695_FastIron-1_2023-05-02_22-17-09.gz
Tue May 2 22:17:09 UTC 2023: Checking integrity of core_2695_FastIron-1_2023-05-02_22-17-09.gz
ln: /lib/libpam.so: File exists
ln: /lib/libpam.so.0: File exists
ln: /lib/libpam_misc.so.0: File exists
ln: /lib/libpam_misc.so: File exists
ln: /lib/libnss_mapname.so.2: File exists
ln: /lib/libnss_mapuid.so.2: File exists
ln: /lib/libtac.so: File exists
ln: /lib/libtac.so.2: File exists
ln: /lib/libtac.so.2.0.0: File exists
cp: can't stat '/.pkg/libpam/etc/*': No such file or directory
adduser: user 'sshd' in use
Setting up ssh key
Setting up ecdsa key
Starting mgmt monitor scrit
Tue May 2 22:17:37 UTC 2023: Moving core_2695_FastIron-1_2023-05-02_22-17-09.gzof size 9760 KB to flash, with available space of 833712 KB...
ERROR2: Core file core_2695_FastIron-1_2023-05-02_22-17-09.gz is probably corrupt !!!
ERROR: Unable to move the core file /core_2695_FastIron-1_2023-05-02_22-17-09.gzto persistent memory
Creating TUN device
Creating the first Tap interface
ERROR: Failure in brctl addbr
ERROR: Failure in brctl addif eth0
ERROR: Failure in brctl addif tap0
ERROR: Failure in ifconfig br0
ERROR: Failure in gw add
Starting TPM Infra
/etc/tpm-infra.sh: line 101: can't create /fast_iron/logs/tpm_infra_init.log: nonexistent directory
adduser: user 'tss' in use
Group tss and User tss created
hostname set to Ruckus-ICX
Starting TCSD Daemon in 'fi' namespace
TCSD did not start
Enabling time stamp.
/etc/init.sh: line 1: can't create /fast_iron/logs/bootmsg: nonexistent directory
Setting Unix datagram queue len.
Setting TCP keep alive params
Moving app to flash....
Moving system log files to persistent memory
Copying SZ log files to persistent memory..
Done.
Core collection and system log collection completed, rebooting the switch ...
Stopping File Manager daemon...
Stopped File Manager daemon
/icx_dhcp_snoop.db -> /fast_iron/
cp: can't stat '/etc/dhclientv4.leases': No such file or directory
/etc/dhclientv4.leases -> /fast_iron/
/icx_dhcpv6_snoop.db -> /fast_iron/
Stopping health monitor daemon...
Stopped health monitor daemon
Stopping poe daemon...
Stopped poe daemon
Stopping system statistics daemon...
Stopped systatsd.
stopping ICX prereqs...
Saving the configuration and license files...
Backup is fine
Stopping tcsd daemon...
Stopped Tcsd daemon
[BRCD]: Sent SIGKILL to all processes
Requesting system reboot
[ 748.820419] reboot: Restarting system
[ 748.864322] Asserting GHPIO[7] reset sequence from Kernel ...
Ruckus Networks Bootloader: 10.1.25T225 (Aug 08 2022 - 04:58:19 -0700)
Booted from partition 1
DRAM: Validate Shmoo parameters stored in flash ..... OK
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
Crashkernel Disabled
device 0 offset 0xbfe00, size 0x200
device 0 offset 0x0, size 0xc0000
Uboot Checksum Verification: PASS
bootdelay: ===
Booting image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
33554432 bytes read: OK
Image Checksum Verification: PASS
## Loading kernel from FIT Image at 70000200 ...
Using 'conf@1' configuration
Trying 'kernel@2' kernel subimage
Description: Ruckus Linux MN VER=09.0.10f
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x702cdbb0
Data Size: 2915298 Bytes = 2.8 MiB
Architecture: ARM
OS: Linux
Load Address: 0x61008000
Entry Point: 0x61008000
Hash algo: crc32
Hash value: 80a6de90
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: crc32
Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 70000200 ...
Trying 'ramdisk@1' ramdisk subimage
Description: Ramdisk -rootfs
Type: RAMDisk Image
Data Start: 0x7059c148
Data Size: 26244590 Bytes = 25 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: crc32
Hash value: f6e77ef5
## Loading fdt from FIT Image at 70000200 ...
Trying 'fdt@3' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x70599ef0
Data Size: 8607 Bytes = 8.4 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 6fc9a37b
Loading fdt from 0x70599ef0 to 0x65008000
Booting using the fdt blob at 0x65008000
Uncompressing Kernel Image ... OK
Using Device Tree in place at 65008000, end 6500d19e
Starting kernel ...
Mounting file system...
booting with 4.4 kernel
PLATFORM MN
dd cmd: UBI
Config partition mounted
Resource partition is mounted!!
eUSB Not mounted or detected
mkdir: can't create directory '/fast_iron/logs': File exists
Successfully read the SKU Reg, the value is: 0xff
dma_mem_base: 0x96000000, dma_mem_len: 0x8000000, warm_mem_base: 0x9f500000, warm_mem_len: 0xb00000
/etc/init.d/rcS: /etc/init.d/S46ufi_pkg_extract.sh: line 75: can't create /fast_iron/logs/ufi.log: nonexistent directory
mv: can't stat '/fast_iron/logs/ufi.log.bkp': Not a directory
/etc/process_packages.sh: line 170: can't create /fast_iron/logs/ufi.log: nonexistent directory
Processing packages from primary partition
Error: : Not a directory
Extract UFI FI version success, version = SPR09010f.bin
Installed packages are up to date
/etc/init.d/rcS: /etc/init.d/S46ufi_pkg_extract.sh: line 1: can't create /fast_iron/logs/ufi.log: nonexistent directory
ICX prereq settings ..
Setting up hostname
Setting up ISC DHCP
ICX prereq settings done
Starting up system statistics daemon...
Starting systatsd done
Starting up poe daemon...
Successfully mapped 4194304 space
Number of hash elements 8000
Number of key objects 4000
Number of contexts 4000
Start of Data region b6137000
Systatsd Logging Env is not set, initializing log level to: D
Setting connection to systemlogger
poed Logging Env is not set, initializing log level to: I
Starting poed done
Starting up health monitor daemon...
Starting hmond done
Hmond Logging Env is not set, initializing log level to: I
nohup: appending output to nohup.out
Backup is fine
Kernel crashdump is disabled.
starting console application
Creating TUN device
Starting TPM Infra
TCSD Up and Running
07-07-2023 05:26 PM
The switch just stopped rebooting but now putty just shows the words: OS
07-10-2023 08:42 AM
Hi @diver19743
Could you please share the screenshot of the screen after reboot showing OS?
