03-26-2024 10:43 AM
Woke up today and my ICX-7150-C12P had no power going to it, my internet router is working, it is plugged into a good power source, I've done the reset procedure and still no power.
03-26-2024 10:53 AM
It sounds like it is fried. Have you started the RMA process? You should be able to get a new unit ASAP
03-26-2024 01:38 PM - edited 03-26-2024 01:39 PM
Hi @Berrybreeze
As per the case description, I understand that your RUCKUS setup is not working, and has no power.
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Please let me know the answers to ALL the above queries and let me know if you have any queries in this regard.
03-26-2024 02:04 PM
I have a support ticket open, #01670510. Do you still need all the info? Because it was working yesterday just fine, and today it is not on with any power or lights. It's plugged into a good source, and there are no lights on anything. The same issue many others were having and their issues were resolved with new units.
03-27-2024 05:45 AM
Hi @Berrybreeze
Please remove your Switch from the networking cabin then plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet. Please refer to the below pictures as an example.
