07-18-2023 02:10 PM
Hi, I previously posted here RUCKUS Forums - Re: ICX 7150-C12P has no power - CommScope RUCKUS Community Forums (ruckuswireless.c...
But I was told to reach out for Lennar Homes support. My Ruckus came with the Lennar home that I bought. It has suddenly quit working due to no power. Probably PSU is gone. I'm looking for help with RMA, but as I understand, an engineer from here is supposed to approve the RMA, can someone please help out? I haven't gotten anymore response in the other thread.
07-18-2023 02:23 PM
Hi @freddycct
Hope you are doing well!!!
From the case description, I could understand that your RUCKUS ICX-7150-C12P Switch is not powering up.
Could you please try to check by replacing another Power cord with the Switch? In case the current power cord is damaged.
Also, please try to reset the Switch as described below:
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
07-18-2023 07:24 PM
How long do you let all the light flash in amber?
07-19-2023 08:13 AM
Hi @Castlcvc
Hope you are doing well.
As this case is raised by @freddycct
To avoid confusion with posts, you can create your own post with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly.
07-20-2023 10:14 AM
Hello Imran,
How long does it take to have support? I did start my own but seems to only receive one response asking if I was a Lennar Home.
