ICX-7150-C12P does not power up, LED blink for a moment then go dark
dbooth
I'm seeing the same issue that was reported here:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/ICX-7150-C12P-not-powering-o...
I have unplugged the Ruckus switch and when I plug it in all of the LED's light up for a split second and then go off.  I have tried plugging the switch into several, good, power outlets and get the same results.
2 REPLIES 2
pinky_ruckus
Valued Contributor III
Hi @dbooth ,
From the case description, I understand that you the Switch is not turning on and the lights are off.
pinky_ruckus
Hello @dbooth ,
Thank you for sharing the details in a private chat.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up even after connecting it to working power outlet, and when plugged in, all lights are off. However, the failure persists. This Switch unit should be RMA (Return Merchandise Authorization) in simple words replacing it.
