11-01-2024 10:59 AM
My ICX 7150 stopped working overnight - no power outage or spike - and now no longer powers on properly. When connecting to known good power source, the status lights flash amber once and then nothing. I cannot connect via serial either. I worked through the hard reset procedure many times (like 15x) and still no luck. Overall, this looks very similar to what other users reported, e.g.:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Ruckus-ICX-7150/td-p/97948
Any suggestions as to how to proceed? Thanks!
JP
11-04-2024 06:32 AM
Hi @jsiedlarek
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
