09-09-2024 07:16 PM
I have a Lennar smart home built in 2018. My ICX 7150-C12P will not stay powered on. When I unplug it in the led light blinks once then it immediately powers off. It will not stay on. I tried reset the ICX as well as power off ICX, turn on ICX while pressing the reset button.
09-10-2024 09:14 AM
Hi @vtjc2002
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
09-10-2024 08:30 AM
Hi, video uploaded. Name of file is PXL_20240910_022323668.TS.mp4
The lamp (white light) is plugged into the same outlet to demonstrate the outlet has power.
09-10-2024 09:14 AM
Hi @vtjc2002
