10-04-2022
10:49 AM
- last edited on
05-27-2025
01:40 PM
by
Imran_ruckus
This article provides a step-by-step guide on upgrading a switch from a non-UFI version to the recommended 08.0.95g UFI version using a USB Flash Drive and PuTTY Applications.
Note: The USB flash drive must be formatted in FAT32 and should be a Standard Type-A USB.
For detailed instructions on how to format the drive on Windows and macOS systems, please refer to the following guide:
Ensure the USB drive is formatted to FAT32 and is a standard USB.
When upgrading from a non-UFI version, we must first upgrade to the initial version (08.0.80f) before proceeding to the recommended version (08.0.95g).
The Upgrade path would be: Non-UFI version before 08.0.80f version>>08.0.80f>>08.0.95g
1. Download and extract/unzip the initial version 08.0.80f
Figure 1: Download path for the initial version
Figure 2: Accepting the download agreement
2. Navigate to the ICX 7150 > Boot directory and copy the mnz10114.bin file.
Figure 3: Downloading the boot file
3. Navigate to the ICX 7150>Images folder and copy SPS08080f.bin
Figure 4: Copy the initial version image
1. Log in to the RUCKUS Support Downloads page .
2. Select RUCKUS ICX7150 Campus Switches from the ‘Choose A Product’ menu.
Figure 5: Download path for recommended version
3. Select 08.0 from the Version menu.
Figure 6: Choosing Download version
4. Select RUCKUS ICX FastIron 08.0.95g (GA) Software Release (.zip).
5. Click Download software.
Figure 7: Downloading the recommended 08.0.95g version
Figure 8: Accepting the Download agreement
6. Unzip the downloaded file and extract all contents.
7. Navigate to the ICX 7150 > Images folder and copy SPS08095gufi.bin and paste in the same folder we created previously.
Figure 9: Copying the download image 08.0.95g version
8. Create a new folder named Upgrade and copy the following files into it: mnz10114.bin, SPS08080f.bin, and SPS08095gufi.bin.
Figure 10: Copying the downloaded images
Insert the USB drive into the designated USB port on the ICX-7150 switch. (Figure 11)
Figure 11: Physical USB Port
1. Connect to the switch using SSH, Telnet, or a console connection.
2. Enter the 'enable’ command to switch to User EXEC mode:
Figure 12: Accessing the Switch CLI
1. Use the 'mount disk0' command to ensure the Switch recognizes the USB.
Figure 13: Switch recognizing the USB
2. Use the 'show files disk0' command to view the contents of the USB drive.
Figure 14: Viewing the contents of USB
Note: The switch has two flash storage partitions, Primary and Secondary.
Figure 15: Display codes on both partitions
Figure 16: Display Switch version
1. Upgrade the bootrom using the command “copy disk0 flash mnz10114.bin bootrom”
Figure 17: Copying the Initial version boot file
2. Upgrade to intermediate version 8080f using the command “copy disk0 flash SPS08080f.bin secondary” (Can install in both primary and secondary partitions)
Figure 18: Copying initial version image
3.Use the command "show flash" to check if it was installed correctly in the right partition.
Figure 19: Check if version was installed
4. Use the command “boot system flash secondary yes” to boot the Switch from the secondary partition to make sure the image was installed correctly.
Figure 20: Boot Switch from Secondary partition
5. Use the 'show version' command to check the current version once the boot process is complete and the version should be 08.0.80f
Figure 21: Checking the current Switch version
1. Use the command “copy disk0 flash SPS08095gufi.bin secondary” to copy from intermediate 08.0.80f to recommended version 08.0.95g.
Figure 22: Copying recommended version image
2. Use the command “boot system flash secondary yes” to boot from the secondary partition once the copy is complete.
Figure 23: Boot System from secondary partition
3. Use the 'show version' command to check the current version once the boot process is complete and the version should be 08.0.95g
Figure 24: Checking the Switch version
For best results, we recommend having both partitions on the same version.
1. Use the command “copy flash flash primary” to re-flash from Secondary to Primary.
Figure 25: Copying same image on partitions
2. Use the command “show flash” to confirm the copy.
Figure 26: Checking the Switch version after upgrade
The RUCKUS ICX-7150-C12P Switch is now upgraded to the recommended version 08.0.95g.
