Ceiling box not working no lights on,
Azuycar
Switcher has two lights on a green which is power on and a yellow light which is next to system, ceiling access points are not being powered no internet access I had this problem in the past where accidentally switcher got unplugged and it was hard for access points to come alive. This recent problem was due to a one or two minute delay power outage
4 REPLIES 4
Imran_ruckus
Community Manager
Community Manager
Hi @Azuycar
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch is not working with green and yellow light and Access Point do not have power.
As you mentioned there are lights on PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly. And this is the reason your RUCKUS ICX-7150-C12P Switch is unable to transmit power (PoE- Power over Ethernet) to the Access Points or on its ports.
First, we will try to reset the Switch as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
Below is the Guide and Videos link and VIDEO for your reference:
Video link: https://www.youtube.com/watch?v=6jHMTdo_hK4
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Video Link: https://www.youtube.com/watch?v=Ql22blH_CGo
Please note, we must use ethernet cable (both ends RJ45 plugs) and USB to type C cable both together as described in steps 2 & 3 in the guide link.
I have the same problem as the guy above the only difference I am having is my system light is green. So both of my lights are green, but my ceiling box has no lights showing. If I reset the system it will boot up and I will be able to connect to the internet for about 30 seconds than the box on the ceiling will just turn off. Any suggestions?
Hi @Cryptoguy777
Hope you are doing well
As this case is raised by @Azuycar
To avoid confusion with posts, you can create your own post with the description you mentioned and what you've done so that we can guide you properly.
Imran_ruckus
Community Manager
Community Manager
Hi @Azuycar
Please follow the process explained in my previous post and let me know if you are stuck at any step or need any assistance during the process.
