Blinking power LED after lightning strike
RedStem1
Need help troubleshooting my ruckus device after lightning strike and power outage
1 REPLY 1
Imran_ruckus
Hi @RedStem1
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working after a power outage.
1. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
