AP not working. Please help
ebalele
I tried following directions from other post however, Ruckus does not come up as a device when I'm do the iP scan.
1 ACCEPTED SOLUTION
Imran_ruckus
Hi @ebalele
Apologies for the inconvenience.
As per the case description, I understand that your RUCKUS setup is not working.
Please let us know the answers to the below queries to assist you better?
1. Was this working before or is it a new installation? If it worked before, was there any power outage before you started facing this issue?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
4. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please let me know the answers to ALL the above queries and let me know if you have any queries in this regard.
3 REPLIES 3
Imran_ruckus
Hi @ebalele
I figured it out already. Thanks!
Hi @ebalele
Great!!! Good to know that the issue is now resolved.
Have a great day ahead!!!
