3 lights are not lit on my AP
KLopez
I have 3 lights that are not lit on the AP and I have restarted it on the actual box in my tech cabinet and reset it as well.
13 REPLIES 13
That has already been done. There is nothing else to be done. What do I do now?
Hi @KLopez
Apologies for the inconvenience.
We may need to check some Switch configurations. Could you please help me with the below details? Please follow the below steps to access CLI and get the output of the below-mentioned commands.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
I am not going to be my own technician for this. Is it under warranty and can a service tech come out? If not, I will need to discontinue using your product as it no longer works.
Hi @KLopez
Apologies for the inconvenience, effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email or remote session. We will be exclusively supporting customers via this community forum support model only.
This forum is on best best-effort support basis.
Please note, as per the Switch and AP light status, they are behaving normally. We may need to check the Switch configuration to fix this issue. Please help us with the command output shared in my previous post. This is a software issue that can be fixed following the troubleshooting steps and as per the policies the replacement is not covered for the software issues or without troubleshooting.
Please follow my previous post and help us with the requested information to assist you further.
However, if you continue to have difficulty following the steps, we recommend that you seek outside help or a technician.
RUCKUS does not have any support team of technicians to support on-site for Lennar Homes.
Thank you again for your understanding.
