ZD 1200 with ZF 7363 or/and other APs such as AP 500
rasmus_hecter
Is it possible to connect both ZF 7363 and other APs  such as AP 500 together, If I buy a Ruckus ZoneDirector ZD 1200 for my system? And does the ZD 1200 have to be installed with a certain firmware/driver to connect to the old ZF 7363?
Thanx for your help.
1 ACCEPTED SOLUTION
syamantakomer
Community Admin
Community Admin
Hi Rasmus,
Both these APs are supported on 9.12.3.0.154.
9.12.3.0.154 is the last version where ZF7363 is supported, so you cannot upgrade to any higher version if you still wish to use ZF7363.
Release notes: https://support.ruckuswireless.com/documents/3253-zonedirector-9-12-3-mr3-refresh9-release-notes
Firmware download link: https://support.ruckuswireless.com/software/2484-zd1200-9-12-3-0-154-mr3-refresh9-software-release
Note: Please read the release notes carefully. Upgrade path should be correct else ZD will factory default itself.
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
4 REPLIES 4
syamantakomer
Community Admin
Community Admin
Hi Rasmus,
Syamantak Omer
Super thanx fro fast reply. Is there any problem installing the firmware if the ZD 1200 is already installed with a newer firmware?
If controller is currently running on a higher version than 9.12.3.0.154, then downgrade is only possible with factory reset.
This means you can downgrade the system directly from your current version, but since it is a downgrade, ZD will factory default its settings and you have to reconfigure it from the scratch.
Syamantak Omer
Thanx alot for the answer- Have a great weekend
Type a product name
