Web filtering and click through options in same ssid
andreas_georgio
Hello I have a client who is interested in using a specific SSID (among other SSID that he wishes to use within his business network) that will handle guests visiting their various branch offices. Since the same guest SSID will be broadcasted in all these different branches, the client wants this SSID network to be as simple as possible. He requires to implement only three things:
a) Click through login for guests
b) Disclaimer/Terms and Conditions (for user to accept when logging)
c) Web Filtering capabilities
Now the problem we are facing is that these two options can be found in two different Ruckus controller options. Option a) and b) is found in the Cloud controller version and option c) is found in Smartzone and Virtual Smartzone option.. This is at least what we found when trying different scenarios. My question here is, are we missing something? Is it possible to configure such an SSID with all these options stated above in either controller environment? (either cloud or virtual)
We also heard rumors that soon cloud will be updated and it will contain a web filtering solution, so if that happens then our problem will be resolved.. Can anyone confirm this???
Thank you
7 REPLIES 7
paul_van_der_cr
Contributor
Web Filtering capabilities, what do they want to filter?
Hello Paul and thank you for your reply.. Client is mainly interested in web filtering pornographic, violence/drugs and p2p sites..
phalguni_nanda
Hi Andreas, you have summarized it well. We just introduced the web filtering feature (separate license) in the SmartZone products. We will roll this out in the Ruckus Cloud solution in the future - I cannot comment on the timelines for availability - but rest assured, it is in our roadmap.
Thank you for your interest and posting.
Phal
phal_nanda
Contributor
Phal
