stacking over copper ICX 7250
hello All,
can we do a stacking  if we connect copper transceiver to uplink port on ICX7250-48P-2X10G ??
1 ACCEPTED SOLUTION
DarrelRhodes
Valued Contributor
Hi Amjad,
The Ruckus certified 10G-BASE-TX RJ-45 optic (10G-SFPP-TX-A) cannot be used for stacking.
Passive and active copper DAC cables are available and can be used for stacking.
For further details please refer to the Ruckus Optics family data sheet for further details: https://www.commscope.com/product-type/enterprise-networking/optical-transceivers/
Also be aware that 10Gb RJ45 optics have high power consumption and generate high temperatures, so it may not be possible to run 2x of these modules side-by-side.
Darrel.
7 REPLIES 7
jijo_panangat
RUCKUS Team Member
Hi Amjad,
What is the transceiver type/model been used for stacking ?
'show media' o/p will help.
Jijo
@jijo_panangat
still don't have the  transceiver
just asking before purchase process
DarrelRhodes
Valued Contributor
Hi Amjad,
Darrel.
@darrel_rhodes
thank you for your quick answer
the same  with 1G copper ?
