06-06-2023 03:14 PM
We are upgrading our network power structure from 120v to 208v Is there anything I need to do to the ICX 7150-48PF before plugging it in to the new power supply? I do not see a selector switch like older switches used to have.
06-07-2023 01:52 AM
Hi Wpfleeger
Thank you for reaching us.
Please refer the below link of Hardware installation guide for more details on 7150 switch installation, do's and don'ts. I hope this helps.
Link :
06-07-2023 07:18 AM
Thank you for replying. While this document tells me that the device is capable of running at both100v and 200v I do not see where it mentions any diferences in configuration between the two. I would imagine that means the devices are hot swapable between different power sources (the power supply auto-negotiates between different voltage) I hope I am correct in that assumption.
06-09-2023 10:05 AM - edited 06-09-2023 10:06 AM
Hi Wpfleeger
Thank you for reverting.
From the pic attached below the 7150s do have a note on the back of the switch saying ‘AC Input Rating 100v to 240v’ (as below for a 7150-48PF). The hardware installation guide has this information as well.
I hope this helps answer your question.
