I need to check the load balancing mode of the lags on the physical switches (ICX6610, 08.0.30t) facing our esxi cluster. On the cluster side, at the virtual switches, the balancing mode is currently "Source and destination IP address". The manual is a bit vague of the modes and I can't seem to find a command to modify the mode in the physical switch.
The manual says (a snippet...):
Layer 2 Bridged TCP/UDP: Source and destination MAC addresses, source and destination IP addresses, and source and destination TCP/UDP
ports.
Layer 2 Bridged IPv4
TCP/UDP
Source and destination IP addresses, and source and destination TCP/UDP ports.
So what is the difference here with "bridged tcp/udp" and "bridged ipv4 tcp/udp"? And are those different, selectable modes?
Eg "src & dst ip address and tcp/udp port" is one of the possible selections on the cluster side. Would that be a better combination for icx?
