Showing results forย
Search instead forย
Did you mean:ย
icx7250 firmware recovery failed
Last night try to recovery my icx7250  but failed , so help need.
the problem are
1  when use update_primary and boot primary ,uboot can't find primary and sencondary flash(no current device selected) ,output as following.
2 when use tftpboot, uboot  said   Wrong Image Format for tftpboot command
could anyone help me recovery this switch ?
ICX7250-Boot> printenv
baudrate=9600
ipaddr=172.21.6.124
serverip=172.21.7.253
netmask=255.255.0.0
ver=10.1.01T215 (Oct 30 2014 - 17:38:34)
Environment size: 149/16380 bytes
ICX7250-Boot>
ICX7250-Boot> show_image
Primary  : no current device selected
EMPTY
Secondary: no current device selected
EMPTY
ICX7250-Boot>setenv netmask 255.255.255.0
ICX7250-Boot> setenv serverip 192.168.1.12 ICX7250-Boot> setenv image_name SPR08080e.bin ICX7250-Boot> saveenv ICX7250-Boot> update_primary Updating PRIMARY image over TFTP Using bcmiproc_eth-0 device TFTP from server 192.168.1.12; our IP address is 192.168.1.49 Filename 'SPR08080e.bin'. Load address: 0x1000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################# done Bytes transferred = 29826604 (1c71e2c hex) no current device selected
TFTP to Flash Done.
ICX7250-Boot> boot_primary
Error: The header crc ffffffff and the calculated  crc 4007851a mismatch
Fatal: Firmware integrity checksum failed
Booting image from Primary
Wrong Image Format for bootm command
ERROR: can't get kernel image!
try boot from tftpboot also failed
ICX7250-Boot> tftpboot
Load address: 0x61007dc0
donedone Bytes transferred = 29826604 (1c71e2c hex) Wrong Image Format for tftpboot command ERROR: can't get kernel image!
10 REPLIES 10
The problem appears to most likely be your bootrom is
I would find a much older version probably something like SPF08060x.bin and see if you can unbrick it with that.
When you do your upgrade, always upgrade only one (1) of the flash slots at once, and ensure to upgrade the bootrom at the same time.
With newer builds it is automated via UFI install packages and before that there was manifest files.
I did not go through the steps of trying to actually recover a 7xxx to test it because I am working from home now and do not have one with me, but it appears that your TFTP transfer was likely successful.
I am not sure what TFTP tool you use, but my personal preference is Ttftp64 by Ph. Jounin for things like this.  It ALWAYS works for sending images, recoveries, uploading/downloading startup-configs, booting via TFTP over the network etc.  It has NEVER let me down in any of those use-cases.
That said, I do not think the TFTP transfer was likely the issue.
thanks a lot , download 8.0.60 and 8.0.40 , update_primary  still show no current device selected.
8.0.60 can't boot from tftpboot , 8.0.40 make progress but still fail ,what your advice ?
ICX7250-Boot> setenv image_name SPR08040.bin
TFTP from server 192.168.2.12; our IP address is 192.168.2.11
Filename 'SPR08040.bin'.
done
Bytes transferred = 24136349 (1704a9d hex)
## Booting kernel from Legacy Image at 61007fc0 ...
   Image Name:   Image
   Image Type:   ARM Linux Kernel Image (gzip compressed)
   Data Size:    24135773 Bytes =    Load Address: 61008000
   Entry Point:  61008000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... Error: inflate() returned -3
GUNZIP: uncompress, out-of-mem or overwrite error - must RESET board to recover
resetting ...
dear  NETWizz , for the  "GUNZIP: uncompress, out-of-mem or overwrite error - must RESET board to recover  resetting ... error "   do I need try 8.0.30 or you have better advices?
I am honestly not sure.  Presumably whatever version comes with the boot rom 10.1.01 packaged with it.  Probably the original code on the device before you upgraded the unit.
Also, what TFTP server are you running?
