icx port status mode selection button not functioning
I've got a number of ICX 7150 switches deployed, on which the port status mode selection button for the LED mode doesn't seem to work, or at least it doesn't do anything - the LED mode does not change. Has anyone seen this before?
3 REPLIES 3
vincent_felisaz
Contributor
Hello Steve
The support of the Status Button was introduced with the 8.0.70 release.
Check the software version on the switches on which it doesn't work.
Cheers
Vincent
yamini_elango_h
Hi Steve
Which model of 7150 , what version is being used ?.If you are on the supported version and still see the issue, kindly open a support case and TAC team can help.
Regards
Yamini
Upgrading to 8.0.90b solved the issue.
