07-11-2019 05:35 AM
07-15-2019 05:16 AM
07-15-2019 05:32 AM
07-15-2019 05:52 AM
07-16-2019 06:23 PM
12-31-2019 12:29 PM
Dec 27 22:36:45:I:SZAgent: Failed to connect to management device at 192.168.10.19 Error: HTTP Response Code 400In case Im wrong, other details that look pertinent to the issue include
dm verify-device-certs Commencing sanity check for device certs ... Verifying files on Non-TPM Platform ... Successfully verified The device key pair is valid The Encrypt/Decrypt test is successful Successfully verified device certs show license Unit License Name L3 Premium Port Speed Upgrade Speed Ports MACsec 1 l3-prem-macsec Yes NA NA NA Yes SSH@icx7450#show stack ***** Warning! stack is not enabled. ***** T=5d1h48m0.7: alone: standalone, 😧 dynamic cfg, S: static ID Type Role Mac Address Pri State Comment 1 S ICX7450-32ZP alone 609c.9f1d.dc90 0 local None:0 +---+ 4/1| 1 | +---+ Current stack management MAC is 609c.9f1d.dc90 show ntp status Clock is synchronized, stratum 3, reference clock is 192.168.10.1 precision is 2**-16 reference time is 3786812526.1705005662 (12:22:06.1705005662 GMT-08 Tue Dec 31 2019) clock offset is 1.2229 msec, root delay is 0.8835 msec root dispersion is 21.5554 msec, peer dispersion is 12.5557 msec system poll interval is 64, last clock update was 143 sec ago NTP server mode is disabled, NTP client mode is enabled NTP master mode is disabled, NTP master stratum is 8 NTP is not in panic mode Dec 31 12:06:11:https_connmgr_send_request>Entered. Dec 31 12:06:11:sz_execute_state_machine>Exit with state/event: SZ QUERY/5, TIMER/2002 RC: 1 Dec 31 12:06:14:sz_execute_state_machine>Entering with state/event: SZ QUERY/5, SZ QUERY RESPONSE/2007 Dec 31 12:06:14:sz_parse_sz_query_response -- Status: 400 << Dec 31 12:06:14:sz_fsm_sz_query_state>Moving to IP:192.168.10.19 because of retry count: 12 Dec 31 12:06:14:sz_execute_state_machine>Exit with state/event: SZ QUERY/5, SZ QUERY RESPONSE/2007 RC: 1 Dec 31 12:06:29:sz_execute_state_machine>Entering with state/event: SZ QUERY/5, TIMER/2002 Dec 31 12:06:29: Build String: size 206 ============ {"serial_number":"xxxxxxxxxxxx", "ipaddress":"192.168.10.7", "macaddress":"60:9c:9f:1d:dc:90", "switch/stack/spx":"switch", "numOfUnits":1, "firmware_version":"SPR08090d.bin", "switch_model":"ICX7450-32ZP"} ==============
