failed to connect ICX 7150 to SZ
tomer_iyar
i have installed an ICX7150-C12-2X1G POE 12-port - Version:10.1.15T225
and i am trying to connect it to my Smartzone vSZ-H - 5.1.1.0.598
i have followed the guide and configure the switch with the "sz Active-list command
and i have verified there is connectivity between both devices on all ports, but this doesnt seem to work for me
SSH@GroupA#show sz status
============    SZ Agent State Info     ===================
Config Status: None     Operation Status: Enabled
State: SZ QUERY             Prev State: INIT                 Event: SZ QUERY RESPONSE
SWR List            : None
Active List         : 10.31.3.8
DHCP Option 43      : No
DHCP Opt 43 List    : None
Passive List        : None
Merged List         : 10.31.3.8
Merged Idx: 0    IP : 10.31.3.8
Switch registrar host: sw-registrar.ruckuswireless.com
Switch registrar discovery retry count: 7
Switch registrar host resolve failure count: 7
SZ IP Used          : 10.31.3.8
SZ Query Status     :
        In Progress. Response Not Received.
sz logs
Jan  1 19:48:35:https_connmgr_send_request>Entered.
Jan  1 19:48:35:sz_execute_state_machine>Exit with state/event: SZ QUERY/5, TIMER/2002 RC: 1
Jan  1 19:48:35:sz_execute_state_machine>Entering with state/event: SZ QUERY/5, SZ QUERY RESPONSE/2007
Jan  1 19:48:35:sz_parse_sz_query_response -- Status: 600 <<
Jan  1 19:48:35:sz_fsm_sz_query_state>Moving to IP:10.31.3.8 because of retry count: 36
Jan  1 19:48:35:sz_execute_state_machine>Exit with state/event: SZ QUERY/5, SZ QUERY RESPONSE/2007 RC: 1
Jan  1 19:48:35:HTTP Request Error:Http remote connection close called.
any ideas? thanks.
30 REPLIES 30
nikita_kulikov
Did you create new SwitchGroup in SmartZone?
no,
but i have just did, is there something else i should do?
thanks for the reply.
I created new SwitchGroup and added my switch in it. That's all.
i see, in my case it fails to be added to SZ so i am before the stage of moving between groups
