brocade interface won't talk to cisco interface
ICX6450-48p stack of 6 switches (one uplink port) no longer communicate with cisco layer 3 switch.  It was working but just stopped.  The only thing that changed was removing a port channel from the cisco and a lag from the ruckus (brocade).
7 REPLIES 7
jijo_panangat
RUCKUS Team Member
Hi Dave,
When you remove the Port channel, the associated ports might get disabled to prevent a potential loop, Pls get this verified.
Jijo
I appreciate the reply but we did in fact check the port status on the cisco and the brocade...all are up...
jijo_panangat
RUCKUS Team Member
Hi Dave,
Ok, I believe Cisco L3 is the gateway switch, Do you see any arps learned on it from the 6450 ?
I did a show arp and I dont see the ip for the brocade...
