brocade WS-C3850 stp-bpdu-guard
I have the stp-bpdu-guard command on each of my ports.  I want the individual port to shut down if it senses a loop, not the layer3 up-link (Cisco) which err-disables it's port, making the switch inaccessible.  What commands do I need to add to accomplish this?  Thanks.
2 REPLIES 2
I found the command.  Add the loop-detection command to either the individual port or by vlan:
(config-vlan-1)#loop-detection
Auto recover err-disable ports by cause:
conf t (global config)
#errdisable recovery cause loop-detection
or this for all causes
#errdisable recovery cause all
err-disable recovery interval 60 (60 = 60 seconds)
#errdisable recovery interval 60
Esteemed Contributor II
Thanks Dave!
