06-07-2024 08:01 AM
I'm looking to procure a second-hand Ruckus 7150-48ZP-E8X10GR. I see some with different codes following the SKU. Some ending with E8X10GR-RMT3 and others ending with E8X10GR2-A and some with nothing else, just E8X10GR. Can someone explain what the differences are between the different SKUs?
06-07-2024 09:10 AM - edited 06-07-2024 09:11 AM
Hello @nautalis ,
Hope you are doing well ,
The RMT3 means Three-year remote support
The A Trade Agreements Act (TAA).
Here is the guide so you can check each SKU and look what you need."Page 11"
RUCKUS ICX 7150 data sheet (commscope.com)
Best Regards
Fernando Vasquez
Hello @nautalis ,
Best Regards
Fernando Vasquez
