02-24-2023 02:08 AM
Hello Everyone,
I'm configuring VSRP in two switches with licenses l3 validated, I want to make a virtual IP address for gateway to make redundance. I have followed in part the help here : https://docs.ruckuswireless.com/fastiron/08.0.60/fastiron-08060-l2guide/GUID-D9FB37DA-C043-42E3-BECC...
But I cant enter the command router vsrp...
Please Help !
02-27-2023 11:49 PM
SWITCH2VSRP#conf t
SWITCH2VSRP(config)#vlan 200
SWITCH2VSRP(config-vlan-200)#vsrp vrid 1
SWITCH2VSRP(config-vlan-200-vrid-1)#ip-address 192.168.1.25
Invalid input -> ip-address 192.168.1.25
Type ? for a list
SWITCH2VSRP(config-vlan-200-vrid-1)#ip-address 10.10.10.1
Invalid input -> ip-address 10.10.10.1
Type ? for a list
SWITCH2VSRP(config-vlan-200-vrid-1)#ip-address 192.168.1.253
Invalid input -> ip-address 192.168.1.253
Type ? for a list
activate Activate VRRPE router
advertise Advertise this backup router to master
backup Configure as VRRPE backup router
backup-hello-interval Set VRRPE back router hello interval
clear Clear table/statistics/keys
dead-interval Set VRRPE dead interval
disable Disable VRRPE router
enable Enable VRRPE router
end End Configuration level and go to
Privileged level
exit Exit current level
hello-interval Set VRRPE advertisement interval
hold-down-interval Set VSRP master hold-down interval
include-port VSRP-only: Include additional ports from
VLAN
initial-ttl Set VSRP initial TTL value
no Undo/disable commands
non-preempt-mode Enable VRRPE non-preempt mode
quit Exit to User level
restart-ports VSRP-only: Set option to restart all VSRP
ports when Master becomes Backup
save-current-values Set VSRP to save current parameters value
show Show system information
track-port Configure VRRPE track ports
write Write running configuration to flash or
terminal
<cr>
02-27-2023 11:51 PM
I wanted to follow the instructions of the process that you sent me but I can't, I sent you commands that I type.
02-28-2023 10:02 AM
Can you please share a show version and show flash with me?
Ayleth Alvarez
Sr Technical Support Engineer | L2 TAC Wired
COMMSCOPE
now meets next
03-05-2023 11:14 PM
ICX7150-C12 Switch#sh version
UNIT 1: compiled on Dec 16 2021 at 03:40:25 labeled as SPS08095f
(31457280 bytes) from Primary SPS08095f.bin (UFI)
SW: Version 08.0.95fT211
Compressed Primary Boot Code size = 786944, Version:10.1.21T225 (mnz10121)
Compiled on Wed Aug 25 06:27:49 2021
HW: Stackable ICX7150-C12-POE
Serial #:FEK3233T0HS
Current License: 2X10GR
8 MB boot flash memory
2 GB code flash memory
1 GB DRAM
STACKID 1 system uptime is 7 hour(s) 50 minute(s) 9 second(s)
The system started at 03:45:21 GMT+00 Thu Dec 16 2021
03-05-2023 11:16 PM
ICX7150-C12 Switch#sh flash
Stack unit 1:
Compressed Pri Code size = 31457280, Version:08.0.95fT211 (SPS08095f.bin)
Compressed Sec Code size = 33554432, Version:08.0.95fT213 (SPR08095f.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.21T225 (mnz10121)
Compressed Sec Boot Code size = 786944, Version:10.1.21T225 (mnz10121)
Code Flash Free Space = 1009766400
