01-28-2021 06:44 PM
Dear All,
First off please excuses me English isn't my native language.
We have two of Brocade ICX7250-48P stacked, the idea behind is to accomplish a failover , whenever switch one is down we will remain online because each server will have two ports connected to each switch.
the issue is Switch number is working fine so ive configured the second switch as stack see below
the issue as next, when I connect the cable to switch 1 doesn't matter which ports I received IP from VLAN1, when I connect it to the second switch I don't get any ip.
I don't know what I have done wrong can someone please point me to the right direction ?
this the output of VLAN1
PORT-VLAN 1, Name DEFAULT-VLAN, Priority level0, Spanning tree Off
Untagged Ports: (U1/M1) 47
Untagged Ports: (U1/M2) 2 4 5 6 7 8
Untagged Ports: (U2/M1) 47
Untagged Ports: (U2/M2) 2 4 5 6 7 8
Tagged Ports: None
Uplink Ports: None
DualMode Ports: None
Mac-Vlan Ports: None
Monitoring: Disabled
this is output of the brief interface
2/1/1 Down None None None None No 141 0 609c.9f4b.808c
2/1/2 Down None None None None Yes N/A 0 cc4e.24e3.49ab
2/1/3 Up Forward Full 1G None Yes N/A 0 cc4e.24e3.49ac
2/1/4 Down None None None None Yes N/A 0 cc4e.24e3.49ad
2/1/5 Down None None None None Yes N/A 0 cc4e.24e3.49ae
2/1/6 Down None None None None Yes N/A 0 cc4e.24e3.49af
2/1/7 Down None None None None Yes N/A 0 cc4e.24e3.49b0
2/1/8 Disable None None None None Yes N/A 0 609c.9f4b.808c
2/1/9 Down None None None None Yes N/A 0 cc4e.24e3.49b2
2/1/10 Down None None None None Yes N/A 0 cc4e.24e3.49b3
2/1/11 Up Forward Full 1G 11 Yes 141 0 609c.9f4b.808c
2/1/12 Up Forward Full 1G 11 Yes 141 0 609c.9f4b.808c
2/1/13 Down None None None None Yes N/A 0 cc4e.24e3.49b6
2/1/14 Down None None None None Yes N/A 0 cc4e.24e3.49b7
2/1/15 Down None None None None Yes N/A 0 cc4e.24e3.49b8
2/1/16 Down None None None None Yes N/A 0 cc4e.24e3.49b9
2/1/17 Down None None None None Yes N/A 0 cc4e.24e3.49ba
2/1/18 Down None None None None Yes N/A 0 cc4e.24e3.49bb
2/1/19 Down None None None None Yes N/A 0 cc4e.24e3.49bc
2/1/20 Down None None None None Yes N/A 0 cc4e.24e3.49bd
2/1/21 Down None None None None Yes N/A 0 cc4e.24e3.49be
02-02-2021 07:48 PM
A tac case will help to understand the setup better and take a remote session as needed.
02-03-2021 12:16 PM
@jijo_panangat I am not sure I understand you, what do you mean with a tac case?
I am new to here so sorry if I didn't get it.
02-03-2021 07:28 PM
Not a problem, TAC is technical assistance center provides round the clock 24/7 technical support services on the Ruckus products online and over the phone.You need an active contract with Ruckus for getting these services.
Pls review the below links for more info.
https://www.commscope.com/support/ruckus-support/
https://support.ruckuswireless.com/buy_support
