04-13-2022 01:50 AM
is it possible to use a secondary ip helper address on a virtual interface to configure a secondary DHCP - Server address for redundancy?
Thank you and regards.
04-19-2022 02:13 AM
Ok is the syntax the same for the secondary address or do I have to add secondary at the end like configuring the secondary gateway.
04-19-2022 03:55 AM
The syntax is the same; check the Command Reference guide for the firmware version you are using.
