Using secondary ip-helper address for DHCP
Mobotix_IT
is it possible to use a secondary ip helper address on a virtual interface to configure a secondary DHCP - Server address for redundancy?
Thank you and regards.
2 ACCEPTED SOLUTIONS
Ok is the syntax the same for the secondary address or do I have to add secondary at the end like configuring the secondary gateway.
kpfleming
The syntax is the same; check the Command Reference guide for the firmware version you are using.
3 REPLIES 3
kpfleming
Yes, but both helpers will receive copies of all DHCP requests, so the servers will have to coordinate between themselves to decide which one will respond.
kpfleming
