Unleashed/ICX7150 C12P problem since 10.0.10F update
lievensict
I recently upgraded my ICX7150-C12P to 10.0.10f SPR firmware from the 09.0.10j.cd4 SPS and since re-adding the switch to unleashed i have the problem that the switch keeps wanting to join on 5.137.250.224.(see screenshot below) Even tho the switch is already connected to unleashed and otherwise working fine.
When approving this "switch" it isn't able to communicate to this specific interface, it also can't be removed. Removing the existing switch doesn't resolve it either. I can get it working again by specifing the correct IP in unleashed for the discovery, but then i get the annoying 5.137.*.* IP back in the approval list. This isn't a valid IP in my subnet, and also never set in the switch. The switch has also been factory reset since the firmware upgrade and the troubleshooting.
Unleashed logs report: Failed to add ICX [c0:c5:20:99:4f:f1]. The ICX already exists. Please enter a different one. The MAC address from the one i specified (my managemt ip) and the one unleashed tries to connect (5.137.*.*) are the same (?)
I'm running unleashed version 200.16.7.0.402, i have tried to upgrade 200.17 but this gave me alot of issues with my R350 AP's.
Schermafbeelding 2024-12-28 172006.pngSchermafbeelding 2024-12-28 172020.png
I would like to keep on the 10.0 track now, but if there isn't any fix or update expected soon i think it's the best to go back to the 9.0 track.
This is what the unleashed logs tell me:
Dec 28 17:39:03 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: start to access ICX as user "super".
Dec 28 17:39:03 RuckusAP Beneden syslog: M8d2023S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: OLD_STATE=[discovery], have_approve=1, icx_username=[]
Dec 28 17:39:02 RuckusAP Beneden ZD-APMgr: Ma33b02S0D0 IPC_thread rcv ping from TACMON
Dec 28 17:38:53 RuckusAP Beneden syslog: M8d2022S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: NEW_STATE=[discovery], delay 10 seconds.
Dec 28 17:38:53 RuckusAP Beneden syslog: M8d2022S0D0 pid=2769[14546], icxd_discovery():ICXD: ICX[id=2]: 5.137.250.224: icx-test-default done, result is [NO_RESULT]
Dec 28 17:38:53 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: lastline "==================== LOGIN(test-default): (Sat Dec 28 17:38:43 CET 2024) ====================", expect "assword:".
Dec 28 17:38:51 RuckusAP Beneden syslog: Mad1fd6S0D0 pid=2769[2769], doJobEx():worker: action:[cleanup-response], Done.
Dec 28 17:38:43 RuckusAP Beneden empty: forked dbclient -y -l super 5.137.250.224
Dec 28 17:38:43 RuckusAP Beneden empty: version 0.6.20b started
Dec 28 17:38:43 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: ping 5.137.250.224 success.
Dec 28 17:38:43 RuckusAP Beneden mping[21230]: status=succ result=34 to_pid=1243 ports=1 ports_signaled=1
Dec 28 17:38:43 RuckusAP Beneden mping[21230]: mping 512: cmd=arping -u -z 195 -q -f -c1 -w1 -S 34 -P 21230 -l/tmp/mping_hm_latency.log -I br0 192.168.168.1 &
Dec 28 17:38:43 RuckusAP Beneden mping[21230]: Target default gateway 192.168.168.1 via br0
Dec 28 17:38:41 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: start to access ICX as user "super".
Dec 28 17:38:41 RuckusAP Beneden syslog: M8d2022S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: OLD_STATE=[discovery], have_approve=1, icx_username=[]
Dec 28 17:38:32 RuckusAP Beneden ZD-APMgr: Ma33b01S0D0 IPC_thread rcv ping from TACMON
Dec 28 17:38:31 RuckusAP Beneden syslog: M8d2021S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: NEW_STATE=[discovery], delay 10 seconds.
Dec 28 17:38:31 RuckusAP Beneden syslog: M8d2021S0D0 pid=2769[14546], icxd_discovery():ICXD: ICX[id=2]: 5.137.250.224: icx-test-default done, result is [NO_RESULT]
Dec 28 17:38:31 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: lastline "==================== LOGIN(test-default): (Sat Dec 28 17:38:21 CET 2024) ====================", expect "assword:".
Dec 28 17:38:21 RuckusAP Beneden empty: forked dbclient -y -l super 5.137.250.224
Dec 28 17:38:21 RuckusAP Beneden empty: version 0.6.20b started
Dec 28 17:38:21 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: ping 5.137.250.224 success.
Dec 28 17:38:21 RuckusAP Beneden syslog: Mad1fceS0D0 pid=2769[2769], doJobEx():worker: action:[cleanup-response], Done.
Dec 28 17:38:19 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: start to access ICX as user "super".
Dec 28 17:38:19 RuckusAP Beneden syslog: M8d2021S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: OLD_STATE=[discovery], have_approve=1, icx_username=[]
Dec 28 17:38:13 RuckusAP Beneden mping[20980]: status=succ result=34 to_pid=1243 ports=1 ports_signaled=1
Dec 28 17:38:13 RuckusAP Beneden mping[20980]: mping 512: cmd=arping -u -z 195 -q -f -c1 -w1 -S 34 -P 20980 -l/tmp/mping_hm_latency.log -I br0 192.168.168.1 &
Dec 28 17:38:13 RuckusAP Beneden mping[20980]: Target default gateway 192.168.168.1 via br0
Dec 28 17:38:12 RuckusAP Beneden syslog: Mad1fc9S0D0 pid=2769[2769], icxd_av_is_supported():ICXD: AV_Profile[icx-id:2,unit-id=1] The model don't support AV profile
Dec 28 17:38:12 RuckusAP Beneden syslog: upgrade_debug: pid=20976, insert_field_to_upgrade_ap_list(): firmware_file open failure
Dec 28 17:38:12 RuckusAP Beneden syslog: upgrade_debug: pid=20976, get_ap_list(): see [/tmp/unleashed_upgrade/upgrade_ap_list_from_election.xml.ready], ap-list ready!
Dec 28 17:38:12 RuckusAP Beneden syslog: upgrade_debug: pid=20976, get_ap_list(): ap-list loop 0.
Dec 28 17:38:09 RuckusAP Beneden syslog: M8d2020S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: NEW_STATE=[discovery], delay 10 seconds.
Dec 28 17:38:09 RuckusAP Beneden syslog: M8d2020S0D0 pid=2769[14546], icxd_discovery():ICXD: ICX[id=2]: 5.137.250.224: icx-test-default done, result is [NO_RESULT]
Dec 28 17:38:09 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: lastline "==================== LOGIN(test-default): (Sat Dec 28 17:37:59 CET 2024) ====================", expect "assword:".
Dec 28 17:38:02 RuckusAP Beneden ZD-APMgr: Ma33b00S0D0 IPC_thread rcv ping from TACMON
Dec 28 17:37:59 RuckusAP Beneden empty: forked dbclient -y -l super 5.137.250.224
Dec 28 17:37:59 RuckusAP Beneden empty: version 0.6.20b started
Dec 28 17:37:59 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: ping 5.137.250.224 success.
Dec 28 17:37:57 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: start to access ICX as user "super".
Dec 28 17:37:57 RuckusAP Beneden syslog: M8d2020S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: OLD_STATE=[discovery], have_approve=1, icx_username=[]
Dec 28 17:37:51 RuckusAP Beneden syslog: Mad1fb7S0D0 pid=2769[2769], doJobEx():worker: action:[cleanup-response], Done.
13 REPLIES 13
thx, i've been testing meanwhile, unleashed 200.15.6.212.20 in combination with icx7150C12P running SPS09010j_cd6 work fine. But upgrading to 10.0.10f results in error as the switch advertises 5.137.250.224. Because lievensict (TS) is running 200.16, i suspect the switch firmware 10.0.10f to be broken instead of an issue in unleashed firmware...
The case was closed, the device has no active support contract.
I have tested in another location with a ICX7150-24P. There I get a different IP, but a whois
says :
inetnum: 5.138.0.0 - 5.138.127.255
netname: Macroregional_South
descr: OJSC Rostelecom Macroregional Branch South
descr: Stavropol, Russia
country: RU
I hope, it is a programming mistake and not a security impact !
Local port: 1/1/1 (not transmitting currently)
+ Chassis ID (MAC address): dcae.eb32.b9a0
+ Port ID (MAC address): dcae.eb32.b9a0
+ Time to live: 120 seconds
+ System name : "SW20-FMGBO-FMG"
+ Port description : "GigabitEthernet1/1/1"
+ System description : "Ruckus Wireless, Inc. ICX7150-24-POE, IronWare Version 10.0.10f_cd1T213"
+ System capabilities : bridge, router
Enabled capabilities: bridge, router
+ 802.3 MAC/PHY : auto-negotiation enabled
Advertised capabilities: 10BaseT-HD, 10BaseT-FD, 100BaseTX-HD,
100BaseTX-FD, fdxSPause, fdxBPause, 1000BaseT-HD,
1000BaseT-FD
Operational MAU type : Other
+ 802.3 Power via MDI: PSE port, power enabled, class 0
Power Pair : A (not controllable)
+ Link aggregation: not capable
+ Maximum frame size: 1522 octets
+ Port VLAN ID: 99
+ Management address (IPv4): 5.138.9.72
I have no support for my testdevice:
However, our records indicate that you do not have an active support contract which provides technical assistance.
So I can't get support.
Michael-St
RUCKUS Team Member
RUCKUS Support is already investigating this topic. I will keep you posted.
