12-28-2024 08:31 AM - edited 12-28-2024 08:41 AM
I recently upgraded my ICX7150-C12P to 10.0.10f SPR firmware from the 09.0.10j.cd4 SPS and since re-adding the switch to unleashed i have the problem that the switch keeps wanting to join on 5.137.250.224.(see screenshot below) Even tho the switch is already connected to unleashed and otherwise working fine.
When approving this "switch" it isn't able to communicate to this specific interface, it also can't be removed. Removing the existing switch doesn't resolve it either. I can get it working again by specifing the correct IP in unleashed for the discovery, but then i get the annoying 5.137.*.* IP back in the approval list. This isn't a valid IP in my subnet, and also never set in the switch. The switch has also been factory reset since the firmware upgrade and the troubleshooting.
Unleashed logs report: Failed to add ICX [c0:c5:20:99:4f:f1]. The ICX already exists. Please enter a different one. The MAC address from the one i specified (my managemt ip) and the one unleashed tries to connect (5.137.*.*) are the same (?)
I'm running unleashed version 200.16.7.0.402, i have tried to upgrade 200.17 but this gave me alot of issues with my R350 AP's.
I would like to keep on the 10.0 track now, but if there isn't any fix or update expected soon i think it's the best to go back to the 9.0 track.
This is what the unleashed logs tell me:
Dec 28 17:39:03 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: start to access ICX as user "super".
Dec 28 17:39:03 RuckusAP Beneden syslog: M8d2023S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: OLD_STATE=[discovery], have_approve=1, icx_username=[]
Dec 28 17:39:02 RuckusAP Beneden ZD-APMgr: Ma33b02S0D0 IPC_thread rcv ping from TACMON
Dec 28 17:38:53 RuckusAP Beneden syslog: M8d2022S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: NEW_STATE=[discovery], delay 10 seconds.
Dec 28 17:38:53 RuckusAP Beneden syslog: M8d2022S0D0 pid=2769[14546], icxd_discovery():ICXD: ICX[id=2]: 5.137.250.224: icx-test-default done, result is [NO_RESULT]
Dec 28 17:38:53 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: lastline "==================== LOGIN(test-default): (Sat Dec 28 17:38:43 CET 2024) ====================", expect "assword:".
Dec 28 17:38:51 RuckusAP Beneden syslog: Mad1fd6S0D0 pid=2769[2769], doJobEx():worker: action:[cleanup-response], Done.
Dec 28 17:38:43 RuckusAP Beneden empty: forked dbclient -y -l super 5.137.250.224
Dec 28 17:38:43 RuckusAP Beneden empty: version 0.6.20b started
Dec 28 17:38:43 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: ping 5.137.250.224 success.
Dec 28 17:38:43 RuckusAP Beneden mping[21230]: status=succ result=34 to_pid=1243 ports=1 ports_signaled=1
Dec 28 17:38:43 RuckusAP Beneden mping[21230]: mping 512: cmd=arping -u -z 195 -q -f -c1 -w1 -S 34 -P 21230 -l/tmp/mping_hm_latency.log -I br0 192.168.168.1 &
Dec 28 17:38:43 RuckusAP Beneden mping[21230]: Target default gateway 192.168.168.1 via br0
Dec 28 17:38:41 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: start to access ICX as user "super".
Dec 28 17:38:41 RuckusAP Beneden syslog: M8d2022S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: OLD_STATE=[discovery], have_approve=1, icx_username=[]
Dec 28 17:38:32 RuckusAP Beneden ZD-APMgr: Ma33b01S0D0 IPC_thread rcv ping from TACMON
Dec 28 17:38:31 RuckusAP Beneden syslog: M8d2021S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: NEW_STATE=[discovery], delay 10 seconds.
Dec 28 17:38:31 RuckusAP Beneden syslog: M8d2021S0D0 pid=2769[14546], icxd_discovery():ICXD: ICX[id=2]: 5.137.250.224: icx-test-default done, result is [NO_RESULT]
Dec 28 17:38:31 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: lastline "==================== LOGIN(test-default): (Sat Dec 28 17:38:21 CET 2024) ====================", expect "assword:".
Dec 28 17:38:21 RuckusAP Beneden empty: forked dbclient -y -l super 5.137.250.224
Dec 28 17:38:21 RuckusAP Beneden empty: version 0.6.20b started
Dec 28 17:38:21 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: ping 5.137.250.224 success.
Dec 28 17:38:21 RuckusAP Beneden syslog: Mad1fceS0D0 pid=2769[2769], doJobEx():worker: action:[cleanup-response], Done.
Dec 28 17:38:19 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: start to access ICX as user "super".
Dec 28 17:38:19 RuckusAP Beneden syslog: M8d2021S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: OLD_STATE=[discovery], have_approve=1, icx_username=[]
Dec 28 17:38:13 RuckusAP Beneden mping[20980]: status=succ result=34 to_pid=1243 ports=1 ports_signaled=1
Dec 28 17:38:13 RuckusAP Beneden mping[20980]: mping 512: cmd=arping -u -z 195 -q -f -c1 -w1 -S 34 -P 20980 -l/tmp/mping_hm_latency.log -I br0 192.168.168.1 &
Dec 28 17:38:13 RuckusAP Beneden mping[20980]: Target default gateway 192.168.168.1 via br0
Dec 28 17:38:12 RuckusAP Beneden syslog: Mad1fc9S0D0 pid=2769[2769], icxd_av_is_supported():ICXD: AV_Profile[icx-id:2,unit-id=1] The model don't support AV profile
Dec 28 17:38:12 RuckusAP Beneden syslog: upgrade_debug: pid=20976, insert_field_to_upgrade_ap_list(): firmware_file open failure
Dec 28 17:38:12 RuckusAP Beneden syslog: upgrade_debug: pid=20976, get_ap_list(): see [/tmp/unleashed_upgrade/upgrade_ap_list_from_election.xml.ready], ap-list ready!
Dec 28 17:38:12 RuckusAP Beneden syslog: upgrade_debug: pid=20976, get_ap_list(): ap-list loop 0.
Dec 28 17:38:09 RuckusAP Beneden syslog: M8d2020S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: NEW_STATE=[discovery], delay 10 seconds.
Dec 28 17:38:09 RuckusAP Beneden syslog: M8d2020S0D0 pid=2769[14546], icxd_discovery():ICXD: ICX[id=2]: 5.137.250.224: icx-test-default done, result is [NO_RESULT]
Dec 28 17:38:09 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: lastline "==================== LOGIN(test-default): (Sat Dec 28 17:37:59 CET 2024) ====================", expect "assword:".
Dec 28 17:38:02 RuckusAP Beneden ZD-APMgr: Ma33b00S0D0 IPC_thread rcv ping from TACMON
Dec 28 17:37:59 RuckusAP Beneden empty: forked dbclient -y -l super 5.137.250.224
Dec 28 17:37:59 RuckusAP Beneden empty: version 0.6.20b started
Dec 28 17:37:59 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: ping 5.137.250.224 success.
Dec 28 17:37:57 RuckusAP Beneden sys_wrapper: icx_test_default():ICXD: ICX[id=2]: 5.137.250.224: start to access ICX as user "super".
Dec 28 17:37:57 RuckusAP Beneden syslog: M8d2020S0D0 pid=2769[14546], icxd_state_loop():ICXD: ICX[id=2]: 5.137.250.224: OLD_STATE=[discovery], have_approve=1, icx_username=[]
Dec 28 17:37:51 RuckusAP Beneden syslog: Mad1fb7S0D0 pid=2769[2769], doJobEx():worker: action:[cleanup-response], Done.
01-12-2025 11:23 AM
I see also the management IP: 5.137.250.224 with cli:
sh lldp local-info
I set the IP to the same as the ve :
lldp advertise management-address ipv4 ....
now it works. It is a workarround not a solution.
Regards!
Dietmar
01-06-2025 01:28 PM
Hi!
Thank you for posting you query, just curious, does reverting the ICX to the previous software correct the issue?
Can they see each other as LLDP neighbors? on ICX with #show lldp neighbor and on the AP cli as:
ruckus(ap-mode)# get lldp neighbors
Monitoring Connected ICX Switches
Is automatic approval enabled?
Did the credentials change? could you please verify we have the correct credentials for ICX approval?
Is there any way we can track where that ip is comming from? is there any rogue DHCP server?
Thanks.
01-12-2025 08:11 AM - edited 01-12-2025 08:14 AM
Thank you for your response. Really appreciate the help.
This is a log from the Unleashed master via the CLI. It does show up here but don't know where it gets it from as why the switch would (apparently) send this out.
ruckus(ap-mode)#get lldp neighbors
LLDP neighbors:
Interface: eth0, via: LLDP, RID: 1, Time: 21 days, 14:42:14
Chassis:
ChassisID: mac c0:c5:20:99:4f:f1
SysName: sw-mer-core-1
SysDescr: Ruckus Wireless, Inc. ICX7150-C12-POE, IronWare Version 10.0.10fT213 Compiled on Nov 27 2024 at 06:25:23 labeled as SPR10010f
MgmtIP: 5.137.250.224
Capability: Bridge, on
Capability: Router, on
Port:
PortID: mac c0:c5:20:99:4f:f2
PortDescr: GigabitEthernet1/1/2
OK
Output from the switch:
SSH@sw-mer-core-1#show lldp neighbors
Lcl Port Chassis ID Port ID Port Description System Name
1/1/2 7047.773c.7b40 7047.773c.7b40 eth0 RuckusAP Beneden
1/2/2 cc98.9136.a4b8 gi10 sw-der-dist-1
I ran a few more command for you to see, that it's not just configured in one of the simple options:
SSH@sw-mer-core-1#show ip
Global Settings
ttl: 64, arp-age: 10, bootp-relay-max-hops: 4
router-id : 192.168.168.2
SSH@sw-mer-core-1#show vlan
Total PORT-VLAN entries: 1
Maximum PORT-VLAN entries: 1024
Legend: [Stk=Stack-Id, S=Slot]
PORT-VLAN 1, Name DEFAULT-VLAN, Priority level0, On
SSH@sw-mer-core-1#show ip interface
sInterface IP-Address OK? Method Status Protocol VRF
Eth mgmt1 10.22.3.45 YES NVRAM up up default-vrf
Ve 1 192.168.168.2 YES manual up up default-vrf
SSH@sw-mer-core-1#show interfaces management 1
GigEthernetmgmt1 is up, line protocol is up
Port up for 21 day(s) 15 hour(s) 31 minute(s) 4 second(s)
Hardware is GigEthernet, address is c0c5.2099.4ff1 (bia c0c5.2099.4ffd)
Configured speed auto, actual 1Gbit, configured duplex fdx, actual fdx
Configured mdi mode AUTO, actual AUTO
Not a Member of any VLAN , port is untagged, port state is NONE
Internet address is 10.22.3.45/24
Yes correct credentials. Turning on automatic approval in Unleashed breaks the connection, i can't add it manually now. So if I turn it off it i can add it manually and it stays.
It is able to ping, but no SSH (also no Telnet). Advanced IP scan shows this:
Pretty sure there is no rogue DHCP server in my network. Haven't seen this IP ever before the update. I'm sure I didn't set it, and it came back even after the reset. Is there any reason this has appeared because of the router firmware?
Even tho this shows up in Unleashed, the connectivity seems fine fortunately. Also, I don't have the time to downgrade now, but will try this hopefully soon if there doens't come another 10.0.10 update. I will update on this post.
Thank you for your time.
01-12-2025 08:42 AM
Hello, I#ve seen the same situation in my homelab, show lldp local-info shows as management ip only the:
5.137.250.224
related to:
% Information related to '5.137.0.0 - 5.137.255.255'
% Abuse contact for '5.137.0.0 - 5.137.255.255' is '[email protected]'
inetnum: 5.137.0.0 - 5.137.255.255
netname: WEBSTREAM
descr: JSC Rostelecom regional branch "Siberia"
remarks: Novosibirsk broadband service
country: RU
A IP bind to the int ve xx, did not anything, I corrected the management IP to want I want :
lldp advertise management-address ipv4 192.168.2.9 ports e 1/1/1 to 1/3/2
Now it works in Unleashed, but this is only a little workarround, not a solution.
Regards.
Dietmar
01-12-2025 11:23 AM
sh lldp local-info
Regards!
Dietmar
