08-19-2022 02:29 PM
I discovered today the batch commands inside of ICX switches. I can see many uses but when I tried I got this:
How can I set recurring jobs if they're cancelled when I disconnect?
Also is this persistent across reboots?
08-19-2022 02:34 PM
See the last point. Reloading would also cancel any batch executions.
08-22-2022 05:21 AM
Well, that's a bummer. I thought I could use this feature to automate some maintenance: keeping the SSH keys updated, backing up configuration files, collect logs, etc.
What are the uses you see in the field?
08-22-2022 06:05 AM
You could certainly use it to make changes after hours, stage new code, etc.
