04-16-2025 01:01 PM
I'm not familiar with Ruckus switches (yet) and we just inherited management of several of them for a customer. We don't have access to the management passwords yet and others have posted how to get past that problem, but before I realized that they were configured in a stack, we consolidated the uplinks to free one switch and brought it back to our office to reset the password. Only then once we were in the CLI did we realize that it was part of a switch stack.
Is there a way through the CLI that I can determine how to properly plug the switch back into the stack? To know which ports I should be plugging in?
04-29-2025 01:58 AM - edited 04-29-2025 02:02 AM
Hi BradRay,
When you remove a member from a Ruckus ICX switch stack and bring it back separately, it loses its stack role unless the configuration is carefully preserved.
Identify Stack Ports:
On the CLI, you can check which ports were configured as stack ports by running:
show stack
or, if the switch was standalone when you accessed it:
show running-config
Look for interfaces where the port type was configured as stack-port or stack unit.
Kayal
