02-07-2023 09:04 PM
Hi All,
I am new to the Ruckus ICX Switches. How do I check the configured interface? Like Cisco products, allow the user to see the interface configuration e,g "show run config int gi 1/1/1 ".
Do we have the same feature for ruckus? I would like to use the same config for another port on ruckus, but I don't know the details of the switch interface.
# show int brief
Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name
1/1/1 Up Forward Full 1G None Yes 7 0 d4bd.4f2e.c7e6
1/1/2 Up Forward Full 1G None Yes 12 0 d4bd.4f2e.c7e7
1/1/3 Up Forward Full 1G None Yes 12 0 d4bd.4f2e.c7e8
Thank you.
02-07-2023 10:45 PM
Command is : show run interface eth1/1/1
02-07-2023 11:03 PM
Hi Jayanth,
Thank you for the reply, but I still can not see the details of the configured port.
Sw1#show run interface ethernet 1/1/1
voice-vlan 6
02-08-2023 05:29 AM
Hey @Ameer
'show run int eth /x/y/z' will you show you interface-level configurations only. 'show run' is the generic command to look at everything as the port may be referenced in multiple places. Here are some others to pull more specific information:
show run vlan (also at beginning of 'show run' - gives vlan configuration)
show run authentication (if applicable - give authentication config)
*for information, but not actual config:
show interface or show interface eth x/y/z
show vlan
show vlan <num>
show vlan eth x/y/z
show vlan brief
show vlan brief eth x/y/z
show stat
show stat eth x/y/z
Hope that helps!
03-18-2023 02:21 PM
How do I check then the configuration of the port? If you run "show run-config" it will show the ports disabled not the ones active.
There should be a way to see each individual interface configuration.
