08-02-2023 07:12 AM
I am using a ICX7550 that i have updated to the lastest FastIron 10.0.10a.
from reading i understand that the ip adress is handeled differently in 10.x versions, and i cant quite figure it out.
I want to add an ip address to one interface that is NOT an management interface. that i want to be able to access the system network and tftp to the switch on the same interface. I believe you call it an inband port? I want to be able to access both my network and the switch from the same port.
The manual suggest to look in the Hardware installation guide. but that guide instructs to enter configuration mode for the interface and write "ip adress x.x.x.x/24" which to my understanding only works for 9.0.x and not for version 10.
so how do i achieve this setting of IP on the new firmware (10.0.10a)?
Thanks!
/Ludvig
08-07-2023 10:34 AM
Hi Ludvigb
Ack and Noted. Thanks for sharing.
That's correct you will be unable to configure ip on a interface which is a part of "ve" interface. You will need follow the below steps to assign a ip address on a port.
I hope this helps
