Ruckus Router is not working
Ved
I just bought home and I have ruckus router here and I can’t use that if I have to use what I have to do
my email is vedpatell9911@gmail.com
7 REPLIES 7
Chandini
RUCKUS Team Member
Hi Ved
Thank you for reaching us.
Could you please let me know if you are from Lennar Homes ?
What is the switch model you are using ?
Could you please help us with more details on requirement you are looking for to setup with the router ?
Ved
RUCKUS ICX 7150-C12P I factory reset but how do I sign in with new user?
Chandini
RUCKUS Team Member
Hi Ved
Ack and Thanks for reverting.
Use the below link to console to the switch and see if you have access to CLI.
Default User : super
Default password : sp-admin
Enter the above user and password if you see that there is a need to enter credentials which you will know when you try accessing switch using console and try to go to manager mode which will look like " Device# " to gain access to CLI of the switch.
Ved
It’s still not working Can you send a technician to my house?
