02-21-2022 03:34 PM
HI,
I am on a bit older code but can the 7750 platform on newer code do BGP per vrf?
The current code I am on can only do BGP in the main table, and VRFs are limited to OSPF / VRRP.
03-03-2022 08:37 AM
Hey Corey,
What code are you on? I have not personally set up per-vrf BGP. Let me check on it and get back to you.
03-03-2022 08:52 AM
Hey Corey,
Are you just looking for the option such as below? I see this in 8090 which is the recommended code for ICX7750.
ICX7750-48C Router(config-bgp-router)#address-family ipv4 unicast vrf blue
Or are you looking for the whole instance to be within the VRF such as the following for OSPF?
device(config)# router ospf vrf corporate
I do not believe this exists in any code.
