I don't think there is a guide that provides precisely what you need, the manuals assume certain prior experience. You can probably look to Ruckus TAC to guide you a little bit.. and of course this forum.
At a high level, if you're just using the switch for switching and PoE you pretty much leave everything at default which uses VLAN 1 (though best practices suggest you change this for a small home network its not a big deal..). all you really need to do is enable power for the ports the APs are connected to.
Assuming you are using ports 1/1/1 and 1/1/2 (sub-in other interface if different):
- config terminal
-- interface ethernet 1/1/1 to 1/1/2
--- inline power
--- exit
-- exit
- write mem
If you want to enable DHCP, set up VLANs, login authorization, etc... then there is a little more to be done.
A really great resource for all of the above is on Youtube with one of our own engineers that has compiled a number of tutorials.. see here for more info:
https://www.youtube.com/user/terryalanhenry/videos
