R510 AP and ICX 7150 - APs shutdown and do not power back on
scott_oram
Here is my setup:
Comporium Zipstream Gigabit fiber main box gets Ethernet from junction box in garage.
The comporium box hands out dhcp addresses and has two built in wifi (2 and 5 GHz) networks enabled.
Lan out of the comporium box goes to the ICX7150 which is connected to two R510s running via POE.  Separate SSID is on the APs
I noticed the AP SSID was dropping, I went to look at the APs and sure enough no lights whatsoever.
So I pulled the plug on the ICX and waited a few minutes and plugged it back in.
After around 4 minutes the APs come back online, but then after a short time, all the lights go out again and the only thing I can do is pull the plug and power cycle the ICX.
I was able to update unleashed to the 200.6 (latest version I believe).
Beyond what I'm doing I am a bit new to the whole AP \ switch configuration world.
Any ideas as to what is causing this and what my next steps should be?
20 REPLIES 20
paul_mcguire_20
Contributor
Yes. show version from cli
scott_oram
Well well... guess I have to pay for premium support just to download the USB C to UART driver?  I can't believe this.
paul_mcguire_20
Contributor
You should just require a ruckus account. I don’t have premium support and can download.
scott_oram
I called 1-855-RUCKUS-1 and Ruckus added me to Lennar's Premium Support account.
Should have this sorted soon... at least I have the USB to UART Driver now!
Did you ever get this resolved? I'm having similar problems.
