Problem routing public lan out over peer to peer up block with gateway
john_herms
Issue routing public lan up block to peer to peer block with gateway
3 REPLIES 3
tim_brumbaugh
Contributor
Need more information than what you have given.
eizens_putnins
Valued Contributor II
If you want help, you need to describe exactly what you have, and what doesn't work. Nobody can help you if you don't describe situation...
hashim_bharooc1
RUCKUS Team Member
Hi John
Hope you are doing great!!!
We need to understand the issue in more details so we can figure out what you are doing?
If you provide details of the data flow and the configuration we can look at it and provide the right solution.
We are not sure what you are exactly  trying to do.
Usually we set default gateway to point to outside world.
Hope this clarifies why we need more info.
Hashim
