Port Up Down but link Normal and Intermittent on ICX 7150-24F
Hi
i have Ruckus ICX 7150-24F with Cooper SFP.
can you help me, how to read this logging on my switch,
The link on these port is normal but intermittent.
 Image_ images_messages_61b17c9149c6e64e2a501452_5c0acf81e94cd3ecf1d5537801146c1c_ICX-50e09118-2a2c-445a-94c4-1a812e9f0316-1930835303.PNG
thank you
9 REPLIES 9
BenBeck
Hey there,
These specific state up/down messages are layer 1; think signal on the wire. I would check the cables, patch paneling, etc. Also, are the optics supported or third party?
@ben_beck
hi there
thanks for answering my question.
the cable is fine, already to check on the other device, the topology is port 1/20, 1/21, 1/23 connect to other switch non icx 1/2,1/3,1/5 via copper sfp. and on the oppenent switch the port is normal, no updown like on ICX log.
what does mean ?
thank for your help
The message seen is layer 1 related, so this would generally be optic, media, patch-panel, etc.
Is this a ruckus-supported optic?
show media validation
show media eth x/y/z
Have you used these optics elsewhere on ICX switches without issue?
no issues these optic use on other icx
