POE module of ICX 7450 24P is not working ?
abilashpr
Contributor III
I tried to enable POE on ICX 7450-24P, but it doesn't show any output.
Core#show po
  poe                         inline power information
  port                        Show port security
  power-savings-statistics    Power savings  statistics
Core#show poe
  DECIMAL      UNIT-ID
  STACKID/SLOT/PORT
  debug-info   show inline power debug information
  detail       show inline power detailed information
  emesg        Event Trace Logging messages
  pd           show pd ports power
Core#show poe
Core#show in
  inline                      inline power information
  interfaces                  Port status
Core#show inline power
  power   show inline power
  DECIMAL      UNIT-ID
  STACKID/SLOT/PORT
  |            Output modifiers
Core#show inline power 1/1/1
Core#
I tried to upgrade the POE firmware on this switch, but the Switch reboots and doesn't upgrade the firmware.
I am running latest 8090.
Stack unit 1:
  Compressed Pri Code size = 32454872, Version:08.0.90T213 (SPR08090.bin)
  Compressed Sec Code size = 32454872, Version:08.0.90T213 (SPR08090.bin)
  Compressed Pri Boot Code size = 786944, Version:10.1.15T215 (spz10115)
  Compressed Sec Boot Code size = 786944, Version:10.1.15T215 (spz10115)
  Code Flash Free Space = 1578074112
Core#
Any help appreciated.
Abilash PR.
5 REPLIES 5
You should still also still do a show inline power detail, too to ensure there is nothing wrong with the POE Firmware. (i.e. that it is present)
I do not have a 7450 /w copper ports, so I will look at a 7150; since, it is in the same family.  What you want to see is a firmware version.  Much of the time when the PoE+ module goes bad on an ICX (have not had this happen on any 7xxx series), those details are simply missing though admittedly it may have been from a bad internal power supply when I had issues because my "show chassis" did not return OK on the particular impacted ICX-6430-48P units back in the day.
SSH@REDACTED#sh inline powe det
Power Supply Data On unit 1:
Power Supply Data:
Power Supply #1:
        Max Curr:       6.9 Amps
        Voltage:        54.0 Volts
        Capacity:       370 Watts
        PoePower:       370 Watts
POE Details Info. On Unit 1 :
General PoE Data:
Firmware
Version
02.1.1 Build 002
Hardware
Version
V2R2
